Activity Forums Apple Final Cut Pro Convert AVCHD
  • Convert AVCHD
    Posted by David Mayer on February 14, 2017 at 5:44 pm
    ClipWrap2 is not working to convert slo motion AVCHD files from Sony FS-5 to ProRes 422.
    How do I convert the files for FCPX?
    iMac (Retina 5K, 27 inch, Late 2015)
    4 GHz Intel Core i7
    16 GB 1867 MHz DDR3
    OS X 10.11.6
    Final Cut Pro X (10.2.3)
    Canon C100
    Pioneer BD-RW BDR-206D (Blu-ray)
    Mike Fitzsimmons replied 9 years, 7 months ago 4 Members · 7 Replies
  • 7 Replies
  • Noah Kadner
    February 14, 2017 at 7:14 pm
  • Jeff Kirkland
    February 14, 2017 at 8:09 pm
    Clipwrap is fairly old. Have you tried its big brother, EditReady for the conversion?
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
  • Mike Fitzsimmons
    February 15, 2017 at 2:57 am
    I import AVCHD file from my Z150 directly into FCPX and tell it to create optimized media. You might need to update to newer FCPX if your version is too old.
    Mike
    \’Burbs of Detroit
  • David Mayer
    February 15, 2017 at 12:39 pm
    will try that – thanks, Noah
    4 GHz Intel Core i7
    16 GB 1867 MHz DDR3
    OS X 10.11.6
    Canon C100
  • David Mayer
    February 15, 2017 at 12:40 pm
    yes editReady did the trick – thanks
    4 GHz Intel Core i7
    16 GB 1867 MHz DDR3
    OS X 10.11.6
    Canon C100
  • David Mayer
    February 15, 2017 at 12:41 pm
    Mike – thanks for the note – turns out we are 5 miles away.
    Wonder if we’ve met?…
    4 GHz Intel Core i7
    16 GB 1867 MHz DDR3
    OS X 10.11.6
    Canon C100
  • Mike Fitzsimmons
    February 15, 2017 at 5:37 pm
    Probably! Small world… Where are you?
    Did you ever try importing directly into FCPX? Should work, if that’s where you’ll edit, saves a step or two.
    Mike
    \’Burbs of Detroit
