Activity › Forums › Adobe After Effects › Convert an turbulent displace to keyframes
  • Convert an turbulent displace to keyframes
    Posted by Simon Coco on July 10, 2016 at 7:14 pm
    Hello there!
    I’m applying a turbulent displace effect on a shape (created with the pen tool) and I’d like to know if there’s a way to convert that effect to keyframes. The objective here is to indicate to the shape how it should look at each frame, so I can completely delete the effect. Not sure if I’m being clear haha
    Let me know if you have an idea!
    Simon
    Dmytro Korolkov replied 2 years, 1 month ago 4 Members · 4 Replies
  • Kalleheikki Kannisto
    July 11, 2016 at 5:41 am
    Render the layer with the effect.
  • Dmytro Korolkov
    December 5, 2022 at 1:08 pm
    The same question here. Any relevant solutions? maybe similar morphing shapes or random animating path plugins or scripts?
    “Rendering the layer”, unfortunately, not the answer.
  • Walter Soyka
    December 7, 2022 at 8:26 pm
    Add a “Wiggle Paths” modifier to your shape layer instead of using Turbulent Displace.
    https://helpx.adobe.com/after-effects/how-to/wiggle-paths-animation-effects.html
  • Dmytro Korolkov
    August 6, 2024 at 1:00 pm
    Have used Auto-Trace after all. Not the best result, but I played with an options and result satisfied me. I’ve prepared a good animated rounded mask for Lottie/Rive export.
