Activity Forums Adobe Illustrator convert ai files + batch processing
  • convert ai files + batch processing
    Posted by Picxsee on October 18, 2006 at 1:24 am
    Hi there,
    I’m hoping you can help me with a batch coversion. I have a sequence of illustrator files that i’m trying to apply an action to in photoshop, and pump them out to import back into after effects as a sequence…
    I’ve tried to do it a heap of different ways but cant quite get it. I’ve tested the action which works fine, its the opening and saving part that are causing the problem.
    I’ve tried it through:
    1) bridge or batch processing – the trouble is with the open command – the file opens but comes up with the
    import pdf dialog box asking for dpi, image size etc, which just stops the processing. I’ve tried adding an open command to the action but that just made that same file open over and over instead of the specified ones.
    2) I also tried it through the script image processor – but this seems to have issues with .ai files – It works fines with other files types but not the illustrator files.
    Any tips/ ideas would be great – perhaps are there any programs that i can convert the ai files to another file type before puting them through the batch process?
    Thanks for your help 🙂
    Picxsee replied 19 years, 11 months ago 1 Member · 1 Reply
  • Picxsee
    October 18, 2006 at 2:10 am
    Okay.. got a little further with a new set of problems:
    – didnt see the “suppress open dialog box” – so that stops the import pdf from popping up but it doesnt seem to like the ai files and comes up with “the parameters for the command Open are not currently valid”
    – Ran the ai sequence back through ae to get jpegs that i could batch process through photoshop, but now the problem is the save as dialog box popping up… ???
    mmm getting closer – can you tell me how to solve this problem – i’ve done batch processing a few times before and i’m sure this never came up so it must be something simple.
    Also – does photohop/ bridge have the capability to batch process .ai files or am i wasting my time there?
    Thanks again in advance
