Activity Forums Adobe After Effects Convert a stroke to a path or shape
  • Convert a stroke to a path or shape
    Posted by Steve Hix on May 9, 2022 at 8:37 pm
    I have a PNG (created in photoshop) that I created a stroke for via Layer Style/stroke. I want to add a trim path to that stroke. How do I do that?
    Andy Kiernan replied 4 years, 3 months ago 2 Members · 5 Replies
  • Andy Kiernan
    May 10, 2022 at 1:27 pm
    maybe… use auto-trace, then use that mask to create a stroke (generate>stroke) use that to trim stroke, apply the layer style to the new stroke and it’ll draw on and off
  • Steve Hix
    May 10, 2022 at 4:38 pm
    Yes, that does work. A lot of prep work for 50+ PNGs to work with. I was hoping for a simple “Convert stroke to path” script or something. I’ve been painting free hand up to now, even though not as accurate.
  • Andy Kiernan
    May 11, 2022 at 9:45 am
    another thought… generate>Vegas… add to png change to image contour and use alpha. Fiddle with settings to get it to be one line and then you can use length as a trim. The only issue I see is that it creates the ‘stroke’ on the inside of the alpha but maybe that’s not an issue! hope this helps
  • Steve Hix
    May 19, 2022 at 5:44 pm
    This is good!
    …and keyframe ‘segment length’ to animate path. Not a lot of flexibility but it works.
    Thanks.
  • Andy Kiernan
    May 20, 2022 at 7:52 am
    great stuff, hope it all goes well
