Activity Forums Adobe After Effects Convert a shape into a mask without auto-trace
  • Convert a shape into a mask without auto-trace
    Posted by Michael Garske on October 16, 2012 at 3:51 pm
    I need to convert a shape layer into a mask.
    I’m starting with an illustrator file and I then use “Create shapes from vector layer” to get a clean shape. I’ve tried auto-trace to generate masks, but I can’t seem to get good results with that.
    I found this documentation for masks and shapes:
    https://helpx.adobe.com/after-effects/using/creating-shapes-masks.html
    under the first section CREATING MASKS it says, “Convert a shape path to a mask path by copying the shape’s path to the Mask Path property.”
    How do I go about doing this exactly? And is this the simplest way to make a mask from a shape or vector layer?
    Thanks in advance for your advice, if I can figure out a way to do this quickly and easily it’s going to be a HUGE help. I’m still new to After Effects so I’m sure this is an easy one for someone out there.
    Michael Powers replied 13 years, 6 months ago 4 Members · 6 Replies
  • Stefan Hinze
    October 16, 2012 at 5:52 pm
    Hey,
    try this:
    Illustrator / select Shape or Path / Copy / AE / new Solid / make a mask on it (any mask will do it) / selct the Mask / Paste
    Maybe you need to scale to the right size…
    Hope this helps!
  • Roland R. kahlenberg
    October 17, 2012 at 1:19 am
    It’s quite a simple process. The source for confusion could be that your target layer, should already have a Mask shape. Otherwise, the pasting procedure will not work.
    Here’s the workflow –
    1) select the Path property from Shape Layer – ensure that you select the word Path, it has a stopwatch icon next to it
    2) select the target layer. create a temporary mask if it doesn’t already have one. select the Mask Path property and paste (CTRL+V)
    Copying a Mask Path to a Shape Layer’s Path property is accomplished analogously.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects ACE/ACI (version 7)
  • Michael Garske
    October 18, 2012 at 2:55 pm
    Thanks so much for your help!
    October 18, 2012 at 4:35 pm
    One important thing to take note with creating Shape Layers with one of the Quick Mask/Shape Tools is to depress the ALT (PC), Option (Mac) key when drawing. This creates paths that are interchangeable between a mask and shape path. Without the ALT/Option modifier key, a Shape Layer’s path is fixed to its designated shape.
    The trick is to notice the absence/existence of the Path property for a Shape Layer.
    HTH
    RoRK
  • Michael Powers
    February 22, 2013 at 3:16 pm
    Great tip about the alt key. Thnx!
    Michael Powers
    Creative Director, Animation
    Crameronline.com
  • Michael Powers
    February 22, 2013 at 3:19 pm
    Also try this script from the redefinery:
    https://www.redefinery.com/ae/view.php?item=rd_ShapesToMasks
    Michael Powers
    Crameronline.com
