Activity › Forums › Adobe After Effects Expressions › Convert a 3D position to 2D position *and scale*
  • Convert a 3D position to 2D position *and scale*
    Posted by Gabriel Grenier on November 17, 2021 at 2:22 pm
    Hi !
    .toComp() will give me the 2D position of a 3D layer. But what if that 3D layer also has its Z position animated and I wanted to translate this to 2D position and Scale, so the resulting 2D layer appears to sit perfectly where the 3D layer is?
    In other words:
    If 3D position [500,400,0] = 2D position [500,400] and a scale of 100%,
    a 3D position of [500,400,-300] would give me a scale of 130% (example)
    What would be the expression for the scale? (relative to the active Camera I would assume)
    Gabriel Grenier replied 4 years, 9 months ago 3 Members · 3 Replies
  • Kevin Camp
    November 18, 2021 at 11:22 pm
    Have you tried leaving the layer 3d but enabling auto-orient towards camera? I think it might accomplish what you are trying to do…
  • Meng Zhiqun
    November 19, 2021 at 3:16 am
    Hi Gabriel,
    .toComp() is generally used for 2d layers. Have you tried .toWorld(), which is used for 3d layers?
  • Gabriel Grenier
    November 27, 2021 at 6:16 pm
    I’ll put the working solution here for future reference.
    The following expressions assume that the target 3D layer is the next one, right under the 2D layer (index+1), but that could be changed of course.
    Expression for position:
    thisComp.layer(index+1).toComp(thisComp.layer(index+1).transform.anchorPoint)
    Expression for Scale:
    L = thisComp.layer(index+1);
    C = thisComp.activeCamera;
    CP = C.toWorld([0,0,0]);
    LP = L.toWorld(thisComp.layer(index+1).anchorPoint);
    dis = length(CP,LP);
    CZ = C.cameraOption.zoom;
    LS = L.transform.scale[0];
    S = LS*CZ/dis;
    [S,S];
