Activity › Forums › Adobe Premiere Pro › Convert 864×480 square pixels to 720×576 widescreen
  • Convert 864×480 square pixels to 720×576 widescreen
    Posted by James Smith on December 24, 2010 at 10:26 pm
    I am trying to import a webcam video which has a square 1.0 pixel aspect ratio, 864×480 into Premiere which is ok, however I want to export to 720×576 PAL Widescreen (1.4 pixel aspect ratio) when I select this during export in Premiere, it makes it 720×576 but with black bars, is there anyway to make it proper 16:9 and 720×576?
    Vince Becquiot replied 15 years, 9 months ago 2 Members · 1 Reply
  • Vince Becquiot
    December 25, 2010 at 7:17 pm
    Hi James,
    If you are seeing small bars, you are likely seeing it in the overscan area, and that’s normal, part of the PAR conversion.
    If you need a perfect screen fill, you can either resize inside a PAL timeline, or use the crop settings above the export preview
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
