Activity Forums Adobe Premiere Pro Convert 50p footage to 30p
  • Shane Ross
    February 25, 2019 at 6:40 pm
    Depends on how you convert. 50p to 30p will remove frames in an irregular manner, and might cause a “skippy” look. 60p to 30p and 50p to 25p are nice even conversions…every other frame removed, so it looks fine. You MIGHT need to run these clips thru and Alchemist for better blending. Depends on how bad you think things look
    Shane
    Little Frog Post
