Activity › Forums › Adobe After Effects › convert 4:3 to 16:9
  • convert 4:3 to 16:9
    Posted by Heather Crank on October 3, 2008 at 2:06 am
    Hello all,
    I just created a piece for a client and they mistakenly gave me the wrong ratio. The piece is currently set at 720×486. How can I re-render this as 16:9 without it looking squished?
    H
    Joey Burnham replied 17 years, 12 months ago 3 Members · 3 Replies
  • Chris Wright
    October 3, 2008 at 3:45 am
    By your title, it sounds like you want to stretch from a square pixel to a widescreen pixel, 4:3 to 16:9, there would be no problem, just black on the sides.
    Is your footage squished or stretched and what is it supposed to be? 4:3 is square, so if I assumed that you accidently switched the ratios backwards and were trying to go from widescreen to square, you would have to choose from these 3 professional approaches to this common squished look problem.
    -Variable
    Fit the input image to the output size. If the
    input and output resolutions do not have the
    same aspect ratio, the output image is stretched.
    -Crop
    Fit the input image into the output resolution
    without distorting it. If necessary, the input
    image is cropped to preserve the aspect ratio.
    -Pad
    without distorting it. If necessary, the aspect
    ratio is preserved by surrounding the output
    image with a black border.
  • Heather Crank
    October 3, 2008 at 4:45 am
    THANKS CHRIS! REALLY, REALLY HELPFUL!
    H
  • Joey Burnham
    October 3, 2008 at 8:51 pm
    Hi.
    You lose quality this way but the easiest way to face a 16×9 is to stretch your material 33% on the y axis and pan/scan the footage if needed. That’s your 16×9 anamorphic.
    Joey
