Activity › Forums › Adobe After Effects › Convert 2D scale to 3D position
  • Convert 2D scale to 3D position
    Posted by Anders Bundgaard on July 8, 2014 at 1:46 pm
    hello all,
    i’ve got a comp where a 2d text layer moves towards camera using scale keyframes… is there a way to convert the scale keyframes to 3d z position keyframes?
    thanks in advance
    anders
    John Cuevas replied 12 years, 2 months ago 2 Members · 3 Replies
  • Anders Bundgaard
    July 8, 2014 at 2:26 pm
    i’ve got a few comps doing different things.
    comp 1. scales from 1000% to 100%.
    comp 2. scales from 100% to 0%.
    does that help?
    anders
  • Anders Bundgaard
    July 8, 2014 at 2:54 pm
    had a feeling there wouldn’t be a short cut. i’ve only got about 150 layers to match… i had hoped there might be a plugin / script that could handle it.
    thank
    anders
  • John Cuevas
    July 10, 2014 at 11:46 am
    You might try in the expressions forum. I could write you up a ease expression that could take could take info from scale and apply it to your z position, but if you truly want to convert scale to position it’s going to take a little more math than I know.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
