Activity Forums Adobe After Effects Convert 25P to 50P
  • Pierre Jasmin
    December 13, 2010 at 6:30 pm
    If what you want is a movie at 50 FPS, rather then a 2X slowmo.
    Simply: drop the 25P movie into a comp, change comp rate to 50 FPS, set input frame rate to 25 in Twixtor, and render out the 50 FPS comp at 50 FPS.
    Pierre
