Activity › Forums › Apple Final Cut Pro Legacy › Convert 25 to 23.98 in Compressor??
Posted by Mark Linthicum on June 8, 2006 at 6:12 pmI am using Compressor to go from HD50i to SD 24p with great results but I have a problem with getting to 23.98, does any one know if this is possible?
In the inspector next to video I select settings and the only option is 24 there is no 23.98.
Mark
John Pale replied 20 years, 2 months ago 3 Members · 4 Replies -
John Pale
June 8, 2006 at 6:24 pmI just tried it. In the inspector (using the 8-bit Uncompressed Codec), I click Video Settings…in the resulting window, I go to the pulldown menu for frame rate and at the bottom I see “Custom”…you can set it whatever you like.
Mark Linthicum
June 8, 2006 at 6:44 pm[John Pale] “I just tried it. In the inspector (using the 8-bit Uncompressed Codec), I click Video Settings…in the resulting window, I go to the pulldown menu for frame rate and at the bottom I see “Custom”…you can set it whatever you like.”
Oh, the hidden custom option right there in front of my face!
Thanks, Mark
Gary Adcock
June 8, 2006 at 6:52 pm[Mark] “Oh, the hidden custom option right there in front of my face!”
Also try conforming the timebase of the clip in Cinema Tools
Convert 25 to 23.98 In Cinema Tools
file > open ” master 25p” File
select “Conform” button
Choose 23.98
Save.
(it works the opposite way too)
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Chicago, IL -
John Pale
June 8, 2006 at 8:08 pmFWIW….The last time I tried something like this in Cinema Tools, it changed the sample rate of the audio to an unusual rate, presumably to keep the audio in sync. I had to render to use it in FCP. Using the Compressor method resulted in a file with a standard sample rate with perfect sync.
