Activity › Forums › Apple Final Cut Pro Legacy › convert 24 fps to 30 fps for XDCAM export
  • convert 24 fps to 30 fps for XDCAM export
    Posted by Paul Laroche on September 19, 2011 at 8:47 pm
    I am trying to creating an MXF file via XDCAM export, does this require video to be 30 fps? If so, how do I convert from 24 fps to 30 fps? Someone mentioned a 3:2 pulldown conversion. What is this?
    Laura Woodlondon replied 15 years ago 2 Members · 1 Reply
  • Laura Woodlondon
    September 22, 2011 at 8:49 am
    As for your 3:2 pulldown conversion. Here’s detailed info:
    Film runs at a rate of 24 frames per second, and video that adheres to the NTSC television standard runs at 30 frames a second. When film is converted to NTSC video, the frame rates need to be matched in order for the film-to-video conversion to take place. This process of matching the film frame rate to the video frame rate is called “3:2 pulldown.”
    Laura
    Laura Wood
