Activity Forums Avid Media Composer convert 16×9 into 4×3
  • convert 16×9 into 4×3
    Posted by Mike Wolfe on August 8, 2007 at 7:12 pm
    the short version:
    all footage shot and edited on our website is posted in 16×9. a major client is asking for us to send video to their website, except that they’re formatted for 4×3. i’d rather not export the sequence and re-import using the “edge crop” setting on the deck….is there a way that i can incorporate, or rather, format my sequence and export into a 4×3 video?
    the only other solution that i’ve come up with is to add a letterbox mask and then export in their 640×480 settings. is there any other way?
    Donosnh replied 19 years, 1 month ago 4 Members · 3 Replies
  • Michael Phillips
    August 8, 2007 at 10:49 pm
    Can you crop to 4:3 during the encode?
    Michael
    anything 24fps
  • Jon Zanone
    August 10, 2007 at 10:38 am
    …Or you could lay a reformat effect on the top of our sequece, giving you a letter boxed 4:3 sequence…
    Jon
    “The Almighty tells me He can get me out of this mess. But He’s pretty sure you’re F%$#*D!”
  • Donosnh
    August 14, 2007 at 7:34 pm
    If you copy your sequence then add an additional video track on top of your copied sequence, you can put a pan and scan effect on the filler in your added track and render. You will then have both a 16 by 9 version and a 4 by 3 version.
