Activity › Forums › Adobe Encore DVD › Conversions and Transcode setts
  • Conversions and Transcode setts
    Posted by Dick Rosebud on December 20, 2005 at 1:37 am
    Converting .dv to PAL DV Stream in Quicktime Pro, should I use Progressive or Interlaced setting? Using converted PAL clip in Encore PAL project, what transcode setting should I select (4, 7, 8Mb, VBR, CBR etc.)? Thank you!
    Dick Rosebud replied 20 years, 9 months ago 2 Members · 4 Replies
  • Tim Kurkoski
    December 20, 2005 at 4:09 pm
    If it’s DV, it’s interlaced.
    Your transcode setting depends on a lot more than just NTSC vs. PAL. How much video do you need to fit on the DVD?
  • Dick Rosebud
    December 20, 2005 at 8:45 pm
    But when Quicktime Pro converts the interlaced NTSC DV to PAL, is PAL interlaced? Only putting 3 minutes on this time, but how seriously does the transcode setting affect quility? Can you give me an overview of your thoughts on the settings?
  • Tim Kurkoski
    December 20, 2005 at 9:53 pm
    Again, DV (both NTSC and PAL) is always interlaced. Even 24 frame progressive video on the Panasonic and Canon 24P cameras is interlaced, it’s just interlaced in a special way so 24P can be extracted from it.
    Your transcode settings always affect quality, though if you’re just encoding with the DV codec I don’t think there’s much you can change. I would just go with the default settings and leave it at that, unless you’re having a specific problem.
  • Dick Rosebud
    December 23, 2005 at 12:48 am
    Thank you Tim!
