Activity › Forums › Compression Techniques › Conversion problem detail are mention any kind of solution
  • Conversion problem detail are mention any kind of solution
    Posted by Azhar Zafar baloch on December 21, 2013 at 6:17 am
    Hello sir
    MPEG stream conversion problem in camera mark conversion
    problem conversion into any kind of codec
    example proress xd cam extra also check
    issue is contrast to much high converted footage but i check the original footage is OK
    brightness shoot is proper converted clips getting problem
    os upgraged istalled to backward also install all types of trick try to handle codec’s install
    Azhar Zafar baloch replied 11 years, 8 months ago 2 Members · 2 Replies
  • Craig Seeman
    December 23, 2013 at 9:01 pm
    Converting can cause changes in levels. Some will use processing filters to compensate.
  • Azhar Zafar baloch
    January 19, 2015 at 6:27 am
    Sir Sorry for delaying reply …
    Problem solve hard drive issue….
    If hard drive getting weak or work load on System.
    Then conversion not proper working From Mpeg Stream And Also i change my grafix card not decklink card ..but issue is hard drive
    now working ok thansk
