Activity › Forums › Adobe Premiere Pro › Conversion of MPEG Audio to PPro
  • Conversion of MPEG Audio to PPro
    Posted by William Mcqueen on February 15, 2008 at 10:29 pm
    Trying to salvage a short video project promotion for someone who lost the original 20 minute edit…
    I converted DVD MPEG audio/video to editable video clips, and now I have four clips of AVIs. Problem is that there is a audible “click” at the break between and I would like smooth over the audio music which begins on one and continues on the next clip. Any suggestions how to do that.
    Cheers,
    Bill in Toronto
    Jon Barrie replied 18 years, 7 months ago 2 Members · 1 Reply
  • Jon Barrie
    February 15, 2008 at 11:26 pm
    Sounds (hahahaha) like you need to get the audio unbroken into the timeline so there is no click because it don’t stop and start.
    I use DVD2avi. search it I usually get a clean audio then have to get the vision in chuncks, but the audio should come out in one go, replace that in the timeline once you have the broken clips you made in sync.
    – Jon 😉
    Or you could record the audio into a camera and tape it then recapture it or hook it upto a Dv cam that outputs analog cable connections through the Firewire cable and record it that way into the computer.
    How many editors does it take to change a light bulb?
