Activity › Forums › Apple Final Cut Pro Legacy › conversion matching HD footage from different cameras
  • conversion matching HD footage from different cameras
    Posted by Pablo Harari on August 19, 2011 at 12:57 pm
    Hi, I have to edit footage that was shot with two different cameras.
    when I drag the different files to Compressor I get this:
    one bunch of footage is
    Description: MVI_0301.MOV
    File Extension: mov
    Estimated size: 20.84 GB/hour of source
    Audio Encoder
    16-bit Integer (Little Endian), Stereo (L R), 48,000 kHz
    Video Encoder
    Format: QT
    Width: 1920
    Height: 1080
    Pixel aspect ratio: Square
    Crop: None
    Padding: None
    Frame rate: 23.976
    Frame Controls: Automatically selected: Off
    Codec Type: Photo – JPEG
    Multi-pass: Off, frame reorder: Off
    Pixel depth: 32
    Spatial quality: 50
    Min. Spatial quality: 50
    Key frame interval: 15
    Temporal quality: 50
    Min. temporal quality: 50
    Average data rate: 46.161 (Mbps)
    and the other:
    Description: DSC_0008.AVI
    File Extension: mov
    Estimated size: unknown
    Audio Encoder
    16-bit Integer (Little Endian), Mono, 11,025 kHz
    Video Encoder
    Format: QT
    Width: 1280
    Height: 720
    Crop: None
    Padding: None
    Frame rate: 24
    Codec Type: Motion JPEG OpenDML
    Pixel depth: 32
    Spatial quality: 50
    how should I convert one of the two cameras’ footage to match the other the best possible way?
    thanks a million,
    Pablo H.
    Shane Ross replied 15 years, 1 month ago 2 Members · 7 Replies
  • 7 Replies
