Activity › Forums › Apple Final Cut Pro Legacy › Conversion issue HD to SD
  • Conversion issue HD to SD
    Posted by Romina Ordóñez on April 25, 2009 at 2:54 pm
    Please help me with this, I have a project edited in HD 1440 x 1080
    upper (odd) 29.97
    I saw the recomendations to capture HD video in DV too late, so I have it all in HD now. I want to compress it for dvd, but the results I have with quicktime conversion are really bad. Compressor, don’t work,so I don’t have that choice right now.
    Is there any possibillity to have a decent dvd compressed from quicktime conversion? I did one with quicktime conversion in dv/ntsc, and the quality was ok, the movements of camera are not good, but I could not get letterbox.
    I tried to print to video, and I could not either, the camera is Sony HDV 1080i/minidv/ CMOS
    my apple is I Mac 24″ 2,8 GHZ
    Thank you, it is my first time working with HD video,
    Romina
    viringaproducciones
    I had touble with capture now in fcp 4.5, then I took the quicktime receipts to the trash and updated quicktime in my G5 Mac Os 3.9 to quicktime 7.5. I solved my capture now problems, and now I finally can do it. But FC do not open my existing projects. It begins to open the project, and in the 18 % the program shuts down inexpectedly saying Kern Protection Failure.
    New projects are fine, I can begin a new project, the problem now is with the existing ones.
    Please if you can help me, I had some work to do.
    Thank you,
    Romina
    Romina Ordóñez replied 17 years, 5 months ago 2 Members · 4 Replies
  • Rafael Amador
    April 25, 2009 at 5:14 pm
    [Romina Ordóñez] “I saw the recomendations to capture HD video in DV too late,”
    I think that is a very bad advise.
    You will always get much better quality from the HDV footage.
    For the rest of the issues, I think you should update your two computers.
    Your G5 can works very well with Leopard, FC 6.0.5, etc.
    Rafael
    http://www.nagavideo.com
  • Romina Ordóñez
    April 25, 2009 at 5:15 pm
    Thank you for your answer, right now I am just dealing with the hd project, I want to compress it for dvd, but compressor doesn’t work. Is there another way to compress hd timeline fine for dv. Quicktime conversion?
    My old G5 had a logic board problem, so I don’t have it right now.
    Thank you again.
    Romina
  • Rafael Amador
    April 26, 2009 at 2:33 pm
    Hi Romina,
    If you have DVDSTP, you can make the downscaling in FC, then the MPEG-2 with DVDSTP.
    rafael
  • Romina Ordóñez
    April 27, 2009 at 4:00 am
    Rafael, thank you. I didn’t have DVDSTP, but I found the way to do it in the quicktime conversion, it took a lot of time, and a lot of disk space, but what was important, it ended with a great quality in dvd.
    I did it like this:
    APPLE PRORES HQ
    Interlaced: top
    dimensions 1920×1080
