Activity Forums Apple Final Cut Pro Legacy Conversion into AVC1 h264
  • Conversion into AVC1 h264
    Posted by Krisztian Majdik on June 20, 2013 at 2:11 am
    I have to submit a film online to a film festival tomorrow and they requested the following codec:
    VIDEO
    avc1 H.264
    1280px720
    fps 25 (video is shot in 24)
    bitrate 821kbps
    AUDIO
    codec: mp4a: MPEG-4AAC LC
    channels: 2
    Sample rate 48KHZ
    Bitrate: 129kbps
    If this would be a regular quicktime H.264, I would have no issues converting in compressor or mpeg streamclip. The avc1 part confuses me. Anyone has an idea how I could proceed with this? The original file is a 1080p prores LT file in 24fps.
    Thanks a lot!
    Krisztian
    Rafael Amador replied 13 years, 2 months ago 3 Members · 3 Replies
  • Rafael Amador
    June 20, 2013 at 3:18 am
    You need to export an Mp4/H264, not QT/H264.
    rafael
  • Francesco Carpano
    June 22, 2013 at 12:46 pm
    Hello,
    I’d like to know how did you manage to get the “codec: mp4a: MPEG-4AAC LC” for the audio setting.
    Thank you for your time!
    Regards
  • Rafael Amador
    June 23, 2013 at 11:13 am
    [Francesco Carpano] “I’d like to know how did you manage to get the “codec: mp4a: MPEG-4AAC LC” for the audio setting. “
    When exporting a QT movie, just go to the audio settings, and select AAC instead of PCM.
    If you export an MP4 with QT, AAC audio is the default setting.
    rafael
