Activity Forums Apple OS X conversion
  • conversion
    Posted by Dan Newton on October 11, 2009 at 6:40 pm
    Hey
    I have two urgent questions which I need help in:-
    1. I have been asked to convert a MOV to a mpeg 2
    now the program I normally use is Sorenson Squeeze and Final Cut Studio Compressor —
    but I normally use Squeeze to do mainly mpeg One CONVERSIONS
    I am not sure how to do a mpeg 2 conversion
    here are the requirements:-
    format: mpeg 2
    width : 720
    height: 480
    crop to center: – 1.333:1
    Padding: None
    frame rate: 30 FPS
    Aspect Ratio: 4:3
    field dominance: automatic
    average daTA RATE: 5 (MBPS)
    MAXIMUM DATA RATE: 7.5 (MBPS)
    Could you tell me the steps I would need to do — to do something like this
    2. I have a video (quicktime mov) which is a Pal format: 720 x 576
    they have asked me to give it in a ntsc format — both as 4:3 and 16:9
    in NTSC format.
    how would i do this if I was to export it as a quicktime movie —
    please help
    what settings would I set to make it in a ntsc format
    Cheers
    Dan Newton replied 16 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
