Activity Forums Compression Techniques Conversion
  • Posted by Dan Newton on October 11, 2009 at 6:43 pm
    Hey
    I have two urgent questions which I need help in:-
    1. I have been asked to convert a MOV to a mpeg 2
    now the program I normally use is Sorenson Squeeze and Final Cut Studio Compressor —
    but I normally use Squeeze to do mainly mpeg One CONVERSIONS
    I am not sure how to do a mpeg 2 conversion
    here are the requirements:-
    format: mpeg 2
    width : 720
    height: 480
    crop to center: – 1.333:1
    Padding: None
    frame rate: 30 FPS
    Aspect Ratio: 4:3
    field dominance: automatic
    average daTA RATE: 5 (MBPS)
    MAXIMUM DATA RATE: 7.5 (MBPS)
    Could you tell me the steps I would need to do — to do something like this
    2. I have a video (quicktime mov) which is a Pal format: 720 x 576
    they have asked me to give it in a ntsc format — both as 4:3 and 16:9
    in NTSC format .
    how would i do this if I was to export it as a quicktime movie as a 4:3 and 16:9 —
    please help
    what settings would I set to make it in a ntsc format
    Cheers
    Daniel Low replied 16 years, 11 months ago 2 Members · 9 Replies
  • 9 Replies
  • Daniel Low
    October 11, 2009 at 10:12 pm
    [Dan Newton] “what settings would I set to make it in a ntsc format”
    You use the settings they have supplied you, start with an MPEG-2 NTSC preset and adjust as they have told you to:
    width : 720
    height: 480
    Padding: None
    frame rate: 30 FPS
    Aspect Ratio: 4:3
    It’s not going to look great as you are ‘standards converting’ from PAL to NTSC. Ideally you’d get your footage professionally standards converted first.
    “There’s no chance that the iPhone is going to get any significant market share. No chance.”
    Steve Ballmer To USA Today: 30 April 2007
    “We and Apple are neck and neck and we’re chasing the two
    other players,”
    Steve Ballmer, referring to Nokia and Research in Motion. October 6th 2009
  • Dan Newton
    October 13, 2009 at 6:49 am
    Hey
    Thanks for the feedback —
    when I use Squeeze — the format comes as mkv or something
    shouldn’t it come with an mpeg output?
    please help
  • Daniel Low
    October 13, 2009 at 7:30 am
    [Dan Newton] “when I use Squeeze — the format comes as mkv or something”
    I’m fairly sure that Squeeze doesn’t support the mkv wrapper. Are you sure that’s it’s not m2v?
    other players,”
  • Dan Newton
    October 13, 2009 at 8:21 am
    whoops my bad
    yes m2v — how come it doesn’t have a mpeg output
  • Daniel Low
    October 13, 2009 at 8:31 am
    [Dan Newton] “yes m2v — how come it doesn’t have a mpeg output”
    That is MPEG-2. ‘m2v’ stands for “MPEG-2 Video”.
    Your audio will be encoded as a separate file ready to be taken into your DVD authoring application.
    https://en.wikipedia.org/wiki/M2V
    other players,”
  • Dan Newton
    October 13, 2009 at 11:07 am
    Hey
    ok two questions
    1. I need to send the mpeg 2 to a client so they can view it on their computer and they only require mpeg 2 — i don’t want to send it to them seperately with the audio.
    2. on squeeze there are numerous options … I.E. lg, dvdlg etc… and when you are in the settings window — do I set it on program or elementary and which option do I choose: lg, dvdlg etc..,
    Please Help
  • Daniel Low
    October 13, 2009 at 12:45 pm
    You need to output a program stream on order for the audio and video to be part of the same file.
  • Dan Newton
    October 13, 2009 at 9:19 pm
    Hey
    so what would the output normally be
    will it be
    .MPEG or .M2V
  • Daniel Low
    October 13, 2009 at 9:29 pm
    [Dan Newton] “so what would the output normally be”
    It depends on the use of the output, but it will never be .mpeg but rather .mpg.
    MPEG-2 can have the following extensions depending on output type.
    .mpg
    .m2v
    .ts
    .m2t
    .mxf
    etc..
    other players,”
