  • Posted by Dan Newton on October 11, 2009 at 6:41 pm
    Hey
    I have two urgent questions which I need help in:-
    1. I have been asked to convert a MOV to a mpeg 2
    now the program I normally use is Sorenson Squeeze and Final Cut Studio Compressor —
    but I normally use Squeeze to do mainly mpeg One CONVERSIONS
    I am not sure how to do a mpeg 2 conversion
    here are the requirements:-
    format: mpeg 2
    width : 720
    height: 480
    crop to center: – 1.333:1
    Padding: None
    frame rate: 30 FPS
    Aspect Ratio: 4:3
    field dominance: automatic
    average daTA RATE: 5 (MBPS)
    MAXIMUM DATA RATE: 7.5 (MBPS)
    Could you tell me the steps I would need to do — to do something like this
    2. I have a video (quicktime mov) which is a Pal format: 720 x 576
    they have asked me to give it in a ntsc format — both as 4:3 and 16:9
    in NTSC format .
    how would i do this if I was to export it as a quicktime movie as a 4:3 and 16:9 —
    please help
    what settings would I set to make it in a ntsc format
    Cheers
    John Fishback
    replied 16 years, 11 months ago
    2 Members · 1 Reply
  • John Fishback
    October 11, 2009 at 9:34 pm
    Going from PAL to NTSC is more complicated than changing from mov to mpeg-2. I’ve always used the Natress standards conversion software. https://www.nattress.com/Products/standardsconversion/standardsconversion.htm I believe Compressor can do standards conversion, but I’ve never tried it, and I’ve read it’s not as good as Nattress. Once you have the NTSC 4×3 mov you’ll have to drop it in a 16×9 timeline and then zoom in to fill the frame. Doing this will cause the image to soften. I’d do the initial conversion to ProRes.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
