Activity › Forums › Apple Final Cut Pro Legacy › Controlling with Wireframe versus Origin/Anchor Point
Posted by Zeke Meginsky on May 24, 2011 at 6:44 pmHi, I have read and found out that positioning your text on the screen with your mouse (wireframe) causes some strangeness and decrease in the quality, and that in moving it with the origin and anchor point coordinates, you keep the quality.
Does this same rule apply with photos and pictures and video too?
Zeke Meginsky replied 15 years, 3 months ago 4 Members · 7 Replies -
David Roth weiss
May 24, 2011 at 6:49 pmYou can move the wireframe manually when roughing-out the moves, but then you’ll need to go back and plug in full numbers into x and y coordinates, with even numbers only on the y-axis.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
Michael Griggs
May 24, 2011 at 7:25 pmBy “even numbers” are you referring to ….2…4…6…8..etc.? or just WHOLE numbers?
David Roth weiss
May 24, 2011 at 7:31 pmWhole number on the x-axis and even whole numbers on the y-axis.
Don’t know exactly why, but characters have to rest on even numbered scan lines to display at their optimal resolution.
David Roth Weiss
Los Angeles
Michael Griggs
May 24, 2011 at 7:35 pmDoes this only apply to text? Or would anything….graphic, still, video clip, etc…. be affected by the loss?
And how much resolution loss are we talking about? Obviously, ANY loss is not optimal, but is it usually noticeable?
David Roth weiss
May 24, 2011 at 7:44 pm[Michael Griggs] “Does this only apply to text? Or would anything….graphic, still,”
Everything works better with whole numbers and even numbers on the y-axis.
[Michael Griggs] “And how much resolution loss are we talking about?”
There’s no overall percentage that applies to everything 100% of the time — It really depends on the individual element, but you should test it yourself. It’s often the difference between useable and unusable.
David Roth Weiss
Los Angeles
Scott Sheriff
May 24, 2011 at 7:56 pm[Michael Griggs] “Does this only apply to text? Or would anything….graphic, still, video clip, etc…. be affected by the loss?”
Anything that has a straight ‘hard edge’ like text, a squeeze back, photos.
Scott Sheriff
Director
https://www.sstdigitalmedia.comI have a system, it has stuff in it, and stuff hooked to it. I have a camera, it can record stuff. I read the manuals, and know how to use this stuff and lots of other stuff too.
You should be suitably impressed… -
Zeke Meginsky
May 24, 2011 at 8:50 pmThanks a lot. This cleared things up. So I can move with the wireframe but ultimately should adjust the numbers. Makes sense.
