Activity Forums VEGAS Pro Controlling which video card is used for GPU use?
  • Controlling which video card is used for GPU use?
    Posted by James Kumorek on December 30, 2011 at 7:22 pm
    Is there a way to control which video card in your system is used for GPU processing when rendering?
    I have a AMD Radeon HD 6870 based card with something like 200 processing streams, and an NVidia GeForce 210 card for supporting a third monitor that has 16 GPU cores.
    When I preview my video, I see (via the AMD performance monitoring tool) that the GPU is being utilized. When I render (with GPU accelleration turned on), the AMD card is not being used at all, but the third montiro on the Radeon card gets a little sluggish, and CPU utilization is only at 33% (instead of 100% when GPU rendering is disabled). So, I’m pretty sure the Radeon card is being used, instead of the AMD card that has more processing cores.
    So, how can I force Vegas to use the AMD card when rendering?
    Stephen Mann replied 14 years, 8 months ago 3 Members · 2 Replies
  • Frederic Baumann
    December 30, 2011 at 10:16 pm
    Did you check the Options > Preferences > Video tab? There is a listbox to select the GPU acceleration device.
    … And if you ask the same question for the FBmn Software plug-ins, the answer is: there is a specific ‘GPU Select’ tool which lets you specify which GPU to be used by these plug-ins. It may be different from the one used by Vegas, potentially leading to even faster rendering/preview! The default behaviour is to detect the most powerful GPU, and use this one.
    Hope this helps,
    Frederic
    FBmn Software: save up to 30 Euros on all plug-ins and bundles until December 31st.
    Check GPU-powered FBmn Software plug-ins to fix White Balance and Exposure issues.
    Want to learn on Sony Vegas Event Pan/Crop tool? Watch my tutorial.
    Or about Keyframes? Watch this one. French version here.
  • Stephen Mann
    December 30, 2011 at 10:44 pm
    I worry when I see mixed graphics cards in one system. This forces Windows to install two different video drivers – and there’s no guarantee that they are compatible.
    I am curious, how long have you had this configuration?
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
