Activity Forums Adobe After Effects Expressions Controlling the Speed of offset Turbulence
  • Controlling the Speed of offset Turbulence
    Posted by Javad Zamani on December 23, 2024 at 6:11 pm
    Hi, I have a solid with fractal noise, I want the noise always going downward so the first thing that comes to my mind is using the offset turbulence parameter and increasing the Y property with the “time” expression. I also want to control the speed of movement so I added a slider control to the same solid and called it “Speed”. I use this code on offset turbulence but the problem is when I animate the Speed from 10 to 5, the movement should go downward with a slower speed but it goes UP, I also make a chart to show the Y changes. I don’t know what is the problem. is my math incorrect or does the code have issues?
    thanks a lot.
    Javad Zamani replied 1 year, 8 months ago 3 Members · 4 Replies
  • Yoan Boisjoli
    December 23, 2024 at 6:54 pm
    Hi Javad!
    I think something like this should work:
    const s = effect("Slider Control")(1).value;
    [value[0], value[1]+time*s]
    Let me know if anything !
  • Dan Ebberts
    December 23, 2024 at 9:16 pm
    That’s essentially what he has already, right? The issue is that it is not straightforward to animate speed in AE. I describe the problem and a solution here:
    https://www.motionscript.com/articles/speed-control.html
  • Javad Zamani
    December 24, 2024 at 3:08 pm
    thanks but it didn’t work.
  • Javad Zamani
    December 24, 2024 at 3:11 pm
    Thanks a lot. The article is exactly what I want.
