Activity Forums Adobe After Effects Expressions Controlling the audio in a slider
  • Controlling the audio in a slider
    Posted by Ken Latman on March 10, 2021 at 5:49 pm
    I relatively know how to setup a group of layers to be attached to slider so they can be visible on and off. Something like the following on the opacity value.
    val=Math.round(comp(“Standard Intro”).layer(“Control Layer”).effect(“Slider Control”)(“Slider”));
    if (val>1 && val<3)
    100
    else
    0
    If I have a bunch of audio clips lined up would it be something like this on the Audio Levels
    if (val>1 && val<3)
    0.00
    else
    -192.00
    Chris Voelz replied 5 years, 6 months ago 2 Members · 4 Replies
  • Chris Voelz
    March 10, 2021 at 9:09 pm
    you’ll need to return the value in an array for an audio layer, so [0 , 0] and [-192 , -192]
  • Ken Latman
    March 11, 2021 at 1:19 pm
    Thank you Chris.
    much appreciated.
  • Ken Latman
    March 12, 2021 at 1:57 pm
    I just tested this a s MOGRT and it doesn’t seem you can choose between audio in one. Is that correct? I am using AE 2020. I am not able to use 2021 at this time do to my work environment.
  • Chris Voelz
    March 15, 2021 at 5:38 pm
    What I have done in a template (NOT a MOGRT) but should work the same is tie each audio layer to a checkbox. Then in the MOGRT the user can choose which audio layer they want by selecting a checkbox. I’ve never played with audio in MOGRT’s so this is all untested.
