Activity Forums Adobe After Effects Expressions controlling saturation
  • controlling saturation
    Posted by Aaron Martinez on December 12, 2008 at 3:58 pm
    i was wondering how a guy could control saturation with an expression. i have a foto that i would like to control with an expression to desaturate and possibly also control the lightness.
    i have thought i would be able to use a hue/saturation effect but i cannot control it for some reason. i then tried a fill but with that i could not reveal the original image. does anyone have a solution for this?
    thanks for the help.
    ps- i used the rgbtohsl expression and then back to rgb. i can control the values with the expression but not to reveal the original material.
    Darby Edelen replied 17 years, 9 months ago 3 Members · 2 Replies
  • Dan Ebberts
    December 12, 2008 at 4:11 pm
    How about duplicating your layer, desaturating the top copy, and using an opacity expression to control the amount?
    Dan
  • Darby Edelen
    December 12, 2008 at 8:38 pm
    [Dan Ebberts] “How about duplicating your layer, desaturating the top copy, and using an opacity expression to control the amount?”
    I was going to suggest something similar. If you use a black solid (or other completely desaturated solid) set to the Saturation blend mode and vary it’s opacity that should do the trick.
    Darby Edelen
