Activity › Forums › Adobe After Effects Expressions › Controlling Rotation Speed
Posted by Bhavesh Jadav on June 19, 2014 at 5:33 amHi,
I created fan in after effects & i want to rotate it with initial speed of zero.
Then it will increase upto certain constant speed. It will Rotate for some time at that constant speed.
After some time it will decrease value until it’s value become zero. Like in real world, when u start the fan it will gradually increases it rotation speed & then rotate at constant rotation speed after some time.
When you switch off the fan, the procedure will be reversed.
Is there any way to do it in after effects?Ernestas Cepulionis replied 9 years, 6 months ago 3 Members · 13 Replies -
Dan Ebberts
June 19, 2014 at 6:14 amThis is one way. It’s not simple, but it works:
https://www.motionscript.com/articles/speed-control.html#linear
Dan
Bhavesh Jadav
June 19, 2014 at 9:07 amThank you for your answer
but i already checked that & i am not getting my results.
I want to do it without keyframes & speed should be controlled by slider control -
Dan Ebberts
June 19, 2014 at 2:50 pmYou would use that technique to integrate/accumulate the value of your slider control.
Dan
Bhavesh Jadav
June 20, 2014 at 6:26 amThank you for answering Dan
Here’s the scenario.
I have adjustment layer which has slider control, which controls the
speed of the fan. There is another layer ‘Fan’. I want to control
rotation of fan layer by speed provided in slider control.
There is no keyframe in any layers. On motionscript, it calculates the area of the graph, but in my case there is no graph.so is there any modification i need to do in that code?
If there is way please tell me. -
Dan Ebberts
June 20, 2014 at 6:37 amSo how are you controlling the value of the slider? You initially indicated that you wanted to animate the speed of the fan, which I assume implies that you’ll be animating the slider value, correct?
Dan
Bhavesh Jadav
June 20, 2014 at 7:10 amslider value is constant.
for example i enter 200 in slider value, the fan will rotate about speed of 200 rps(but not necessary 200 rps, around that value) with slowly increase its speed, 200 rps for some time & slowly decrease the speed & then stop. I am not animating slider value. -
Dan Ebberts
June 20, 2014 at 5:45 pmHow does the expression know how long the ramps are and when they start? If you define the ramp start and finish times in the code, I guess it would look something like this:
spd = effect("Slider Control")("Slider");
t1 = 0; // on-ramp start
t2 = 1; // on-ramp finish
t3 = 5; // off-ramp start
t4 = 6; // off-ramp finishif (time > t4){
accum = (t2 - t1)*spd/2 + (t3 - t2)*spd + (t4 - t3)*spd/2;
}else if (time > t3){
v = linear(time,t3,t4,spd,0);
accum = (t2 - t1)*spd/2 + (t3 - t2)*spd + (time - t3)*(v+spd)/2;
}else if (time > t2){
accum = (t2 - t1)*spd/2 + (time - t2)*spd;
}else if (time > t1){
v = linear(time,t1,t2,0,spd);
accum = (time - t1)*v/2;
}else{
accum = 0;
}value + accum
Dan
Bhavesh Jadav
June 20, 2014 at 5:58 pmThank you for answering Dan.
According to your code the speed will increase from 0 to 1 sec & from 1 to 5 sec it wil be constant , then from 5 to 6 second it will decrease & finally it will stop. Right?
1 second ramp i want. I forgot to mention that. -
Bhavesh Jadav
June 20, 2014 at 6:10 pmOh Great.
Thank you Dan.
I will let u know if it works.
Thank you.
