Activity Forums Adobe After Effects Expressions controlling Point Control in a precomp
  • controlling Point Control in a precomp
    Posted by Bert Brown on April 22, 2008 at 4:49 pm
    i saw a recent post about controlling an angle control within a precomp, how can i switch it to controlling a point control instead?
    i’m using Dan’s reverse IK for just the right arm (using all the same labels, precomp is called “arm”)
    but i’m using it in a 2.5d character, so the precomp is 2D but it goes into a 3D comp.
    i just want to be able to move the r hand effector from outside of the precomp
    peep my over-the-interweb band, red abbott.
    “we electro-rock over long distances…”
    Bert Brown replied 18 years, 4 months ago 2 Members · 3 Replies
  • Trent Armstrong
    April 28, 2008 at 8:05 pm
    Try opening your comp with the control and selecting the layer that has the control on it.
    Then LOCK the effects pane and switch to the comp that needs the expression. You can then use the pick whip to choose the point control. When you’re done, click the Lock again.
    Post back if that’s not enough info.
    Trent
    Trent Armstrong – Creative Cow Leader
    https://www.dallasaeug.com
  • Bert Brown
    April 28, 2008 at 8:39 pm
    thanks for the response. i was actually able to figure it out by the code alone, but your method is clearly easier and i really appreciate your help.
  • Bert Brown
    April 30, 2008 at 6:03 pm
    i have a new question. i’ve got a Point Control outside of the precomp to control moving pictures within it.
    it works fine until i keyframe it. then i lose my control, nothing happens.
