Activity Forums Maxon Cinema 4D controlling particles with sound effector
  • controlling particles with sound effector
    Posted by Mihai Wilson on May 6, 2007 at 2:51 am
    Hi there, Im just breaking into C4D and wondering if anyone could enlighten me on how I would control aspects of an emitter using the sound effector. For example, having volume control particle number or spread angle, etc..
    Mihai Wilson replied 19 years, 4 months ago 2 Members · 9 Replies
  • 9 Replies
  • Adam Trachtenberg
    May 6, 2007 at 5:12 am
    You would set up something like this: https://www.3danvil.com/temp/mograph_xpresso.jpg
  • Mihai Wilson
    May 6, 2007 at 6:30 am
    Thanks Adam, that gave me a good start but Im still having trouble. Ive set things up like your example, but I’m getting a result of 0 coming out of the ‘strength’ node on the sample effector. Im sure Im just missing something silly as I am a newb. Thanks.
  • Adam Trachtenberg
    May 6, 2007 at 3:54 pm
    Does your sound effector work if you apply it directly to a mograph cloner or matrix object?
  • Adam Trachtenberg
    May 6, 2007 at 3:55 pm
    Also, you have to adjust your range mapper value to appropriate values.
  • Mihai Wilson
    May 6, 2007 at 6:18 pm
    Yes, silly mistake on my part — it is working now. Thanks Adam.
    One thing Im noticing tho is that I cant control the birthrate with this system. Im guessing that would require thinking particles instead?
    thanks for your help!
  • Adam Trachtenberg
    May 7, 2007 at 4:46 am
    q[ookook] “One thing Im noticing tho is that I cant control the birthrate with this system. Im guessing that would require thinking particles instead?”
    Yep, you can. You’ll find it under the TP>Emitter node’s “Particle” flyout menu.
  • Mihai Wilson
    May 7, 2007 at 5:21 am
    ah cool i see it now, but only renderer, not editor?
  • Adam Trachtenberg
    May 7, 2007 at 1:43 pm
    [ookook] “ah cool i see it now, but only renderer, not editor?”
    ? I’m seeing both here–first two entries in the list.
  • Mihai Wilson
    May 7, 2007 at 5:07 pm
    duh. my bad, I must have messed something up with the emitter with all my fooling around. Tried it with a new one and it works just dandy! Thanks a lot for helping out such a helpless newb.
