Activity Forums Maxon Cinema 4D controlling object visibility with falloff sphere
  • controlling object visibility with falloff sphere
    Posted by Gavenesh Patel on September 20, 2015 at 11:56 pm
    I have what maybe a newbie question for C4D.
    I have a complex piece of geometry and I want to control which parts of it are visible with sphere shape (not sure what else to call it) with fall off. So whenever the geometry and the sphere shape intersect, only the part of the geometry within the sphere is visible when rendered.
    Any help will be appreciated. Thanks.
    Brian Jones replied 11 years ago 3 Members · 3 Replies
  • Brian Jones
    September 22, 2015 at 10:44 pm
    it’s an old channel shader and will look odd in the viewport but look up the Proximal channel. There are number of tutorials out there – you want to use it in the alpha channel of the textures of your complex piece of geometry.
  • Adam Trachtenberg
    September 23, 2015 at 12:04 am
    Proximal works but I find it so fiddly to deal with. My preference would be to do this using Yader’s brilliant vertex map falloff trick. Basically he uses a pose morph to morph between a zero % vmap and a 100% vmap and then applies a morph deformer to provide the falloff.
    https://vimeo.com/58290519
    Then it’s just a question of putting the Effects>Vertex Map shader in the alpha channel.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Brian Jones
    September 23, 2015 at 1:37 am
    nice, I saw the earlier version with xpresso but missed this. Doesn’t allow alpha in the middle of a poly though only a gradient across a full poly so if the object has large polys anywhere the alpha is limited to poly size.
