Activity › Forums › Adobe After Effects Expressions › Controlling Layers inside a Precomp
  • Controlling Layers inside a Precomp
    Posted by Mikhail Shraga on April 10, 2008 at 4:45 pm
    Hi.
    I’m new to expressions. I’d like to learn to control elements within a pre-comp. Is that possible.
    For example:
    i ma working in a composition called Maincomp.
    Layer1 is a null. It has an Angle Control in its effects.
    Comp2 is a pre-comp which contains the layer Square inside of it.
    Can i use the angle control in Layer1 to control the scale of Square?
    many many thanks!
    Dan Ebberts
    replied 18 years, 5 months ago
    3 Members · 3 Replies
  • Dan Ebberts
    April 10, 2008 at 4:54 pm
    Sure – the syntax will look something like this:
    temp = comp(“Maincomp”).layer(“Layer1”).effect(“Angle Control”)(“Angle”);
    [temp, temp]
    Dan
  • Fernando Gutierrez
    April 10, 2008 at 7:34 pm
    Ok, but going a bit further…
    on the main comp, i got a camera, that is already rotaded and etc…
    inside the pre-comp there is a 3D layer… how to make it always “looking” into the camera angle?
  • Dan Ebberts
    April 10, 2008 at 8:01 pm
    Something like this:
    c = comp(“Maincomp”);
    l = c.layer(thisComp.name);
    p = l.fromWorld(c.activeCamera.toWorld([0,0,0]));
    lookAt(p,position)
    Dan
