Controlling how vertices animate when copying keyframes between paths
Hi everyone, I have done some digging and can’t seem to find an answer to this issue which I keep running into when animating paths.
I am trying to animate a square shape from a flat top down view to an isometric view. I have created both states in illustrator and am attempting to copy the keyframes from the corresponding shape paths in the isometric state to the shape paths in the top down flat state.
The problem is some of the shapes’ vertices move to the wrong points meaning the effect doesn’t work (it instead looks like the shape is twisting). Is there any way to control where/how the vertices move when copying keyframes from one shape layer to another other than to move them manually? (The aim is to animate a much more complex shape therefore I’m trying to automate the tweens as much as possible)
The other issue is that the shapes move out of alignment after the transition, any tips on how to deal with this?
Any help hugely appreciated!
Here is a quick test to illustrate the issue, and an image of the final image to be animated:
“To country people Cows are mild,
And flee from any stick they throw;
But I’m a timid town bred child,
And all the cattle seem to know.”
