Activity Forums Apple Final Cut Pro Legacy Controlling FCP audio from MIDI control panel?
  • Controlling FCP audio from MIDI control panel?
    Posted by Michael Buday on June 28, 2006 at 7:24 pm
    I have a USB/MIDI controlled Behringer BCF-2000 mixer panel with flying faders that I’ve been using with FCP with great success. It’s fantastic for performing quick manual mixes and has been working perfectly until recently.
    Now, when I attempt to control the faders on FCP from the mixer while FCP is playing, the audio will cut out for no reason. The only way to hear the audio again is to stop and restart playback, but of course the problem returns after a moment of flying the faders again. Pulling the faders from FCP’s audio panel works fine, it only doesn’t work correctly when learning keyframes from the hardware mixer.
    The panel works fine in Soundtrack Pro, so I’m wondering if this is an issue with the latest FCP build. Anyone else having this issue? If so, have you found a solution? I’ve already trashed preferences etc. with no luck.
    Michael Buday
    Michael Buday replied 20 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
