Activity Forums Adobe After Effects Expressions Controlling color with checkbox controller
  • Controlling color with checkbox controller
    Posted by Christian Simpson on September 5, 2017 at 11:43 pm
    I was wondering if there was a way to control the color values used with the Fill effect based on whether a checkbox was checked or not. For example if i had a solid with the fill effect applied and I had an adjustment layer with 32 different checkboxes. One checkbox could be named Red, the other Blue and so on. Is there a way depending on which checkbox I check that the color values I assign in the expression become active? In other words multiple instances of if/else?
    Connor Betts replied 6 years, 1 month ago 4 Members · 7 Replies
  • 7 Replies
  • Dan Ebberts
    September 6, 2017 at 6:31 am
    Sure, here’s a simple example with 5 colors:
    L = thisComp.layer("Controls");
    if(L.effect("Red")("Checkbox").value)
    [1,0,0,1]
    else if (L.effect("Green")("Checkbox").value)
    [0,1,0,1]
    else if (L.effect("Blue")("Checkbox").value)
    [0,0,1,1]
    else if (L.effect("Yellow")("Checkbox").value)
    [1,1,0,1]
    else if (L.effect("Orange")("Checkbox").value)
    [1,.5,0,1]
    else
    value;
    Dan
  • Christian Simpson
    September 6, 2017 at 5:59 pm
    You’re wonderful Dan, thank you very much for your expertise. Worked like a charm
  • Connor Betts
    August 8, 2020 at 6:50 pm
    I realize this is an older post, but I’m attempting to do the same thing. A toggle between two colors. However I can’t figure out the color system this is using. I’ve spent a while looking around online and I can’t find an answer.
    Is there a way to do this with a hex code or rgb values?
    Thanks.
  • Dan Ebberts
    August 8, 2020 at 7:24 pm
    The color channels are normalized to be between zero and one. You could use 0-255 values like this (example for yellow):
    [255,255,0,255]/255
    Dan
  • Chaz Chester
    August 9, 2020 at 1:53 am
    You can also convert hex to this format using this expression that Dan Ebberts and Scott McGee figured out:
    txt = “FFFFFF”; //the hex code
    hex = parseInt(txt,16);
    r = hex >> 16;
    g = (hex & 0x00ff00) >> 8;
    b = hex & 0xff;
    [r/255,g/255,b/255,1]
  • Connor Betts
    August 9, 2020 at 2:34 pm
    Thanks! This worked for me, i was missing dividing it by 255 when i was trying it.
  • Connor Betts
    Thanks, this is good to know! It worked.
