Activity › Forums › Adobe After Effects Expressions › Controlling color and scale with a Null’s position?
  • Controlling color and scale with a Null’s position?
    Posted by Simon Terrey on September 21, 2015 at 3:55 pm
    Hi everyone!
    I’m making a timeline where when I move a Null, data panels attached to the timeline scale in size.
    I’ve managed to find a script to do this (which I assign to the scale parameter of the data panels):
    So when I move the Null (called Scale_Control) towards the panels the panels grow! Great. But what I want to do as well is change their color as they grow in size and go back to their original color when the Null has passed-on. I’ve looked everywhere and know I need to convert the colors to HLS with an array (I think) and use a similar approach to the scale expression above but I can’t get it to work.
    Hope you can help?
    mouse_layer = thisComp.layer("Scale_Control");//Mouse layer
    beginScale = 75;//Scale begins at this
    endScale = 100;//Scale ends at this
    beginDistance = 200;//Distance to begin magnifying in pixels
    endDistance = 0;//Distance to end magnifying in pixels
    //--Don't modify below here
    dis = length(this.position, mouse_layer.position);
    val = ease(dis, beginDistance, endDistance, endScale, beginScale);
    [val, val]
    Simon Terrey replied 11 years ago 2 Members · 7 Replies
  • 7 Replies
  • Dan Ebberts
    September 21, 2015 at 4:24 pm
    You didn’t mention exactly what you want the color to do.
    Dan
  • Simon Terrey
    September 21, 2015 at 4:26 pm
    Hi Dan,
    I just wanted it to change from grey to orange as it scales-up, then go back to grey when it scales back-down again.
  • Dan Ebberts
    September 21, 2015 at 4:37 pm
    If you applied a Fill effect you could use something like this on the Color parameter:
    beginColor = [.5,.5,.5,1]; // grey
    endColor = [1,.5,0,1]; // orange
    ease(dis, beginDistance, endDistance, endColor, beginColor);
    Dan
  • Simon Terrey
    September 21, 2015 at 4:45 pm
    Hi Dan,
    Many thanks for getting back to me with this!
    I’ve just tried it on the Fill layer (of my shape layer) and it returned with this:
    Error at line 0 in property ‘Color’ of layer 15 (‘DataPanel 11’) in comp ‘Timeline’.
    Object of type Layer found where a Number, Array, or Property is needed.
    This was the message that flagged-up when I tired other techniques earlier…
  • Dan Ebberts
    September 21, 2015 at 5:00 pm
    I hadn’t tried it on a shape layer (I was using a solid with the Fill effect), but it seems to work fine for me (with a shape layer, the anchor point will need to be at the center of the shape). The only way I can generate your error message is to leave out everything except the first line.
    Dan
  • Simon Terrey
    September 21, 2015 at 5:17 pm
    Hi Dan,
    I’ve just tried uploading a small comp aep file with my controller Null and a shape layer (and a new solid with fill) to show you what i’m doing.
    I tried your expression on a new Solid with a fill and it flagged the same error message!
    Are expressions different between CC versions by any chance?
    Simon
  • Simon Terrey
    September 21, 2015 at 5:24 pm
    Hold the fort!
    I’ve got it working. When I paste the expression in, it goes in on one line.
    As soon as I added returns at the end of each line to match-up with the original the error message went away and it’s all good!
    Dan the Man!
    Thank you very much.
    Simon
