Activity Forums Adobe After Effects Controlling CC Drizzle effect
  • Controlling CC Drizzle effect
    Posted by Scratchy_bollock on May 4, 2007 at 6:34 pm
    I’m trying to create a water ripple effect in After Effects 7 viewed from above. CC Drizzle pretty much gives me the exact look I’m going for but the problem is I only want one ripple that I can place where I want in the composition(Instead of the random assortment it generates on screen at any one time). Bit like that bit in Donnie Darko I guess where he touches the mirror. Is this possible?
    Any help would be greatly appreciated.
    Cheers,
    Ian Gray
    Hency Parmar replied 16 years, 3 months ago 3 Members · 3 Replies
  • Darby Edelen
    May 4, 2007 at 7:59 pm
    You can use Effect>Distort>Ripple, or for a greater degree of control (and render time) you can use Effect>Simulation>Wave World. Look for tutorials on the latter if you’re confused, or post again for specific information. The basic idea is you would render it as a height map and then use this as the source for a displacement map.
  • Scratchy_bollock
    May 4, 2007 at 10:03 pm
    Thanks for that, I’ll have a look at the tutorial and try and figure it out.
    Cheers,
    Ian
  • Hency Parmar
    June 11, 2010 at 7:24 pm
    hello
    i tried using cc drizzle
    bt its facing the camera
    i want it on the road and its perspective…
    i also tried making the layer 3d
    bt i m nt able to rotate it…
    can anyone plz help me…
    hencyp@gmail.com
