Activity Forums Adobe After Effects Expressions Controlling a Keyframe Value with Expressions
  • Controlling a Keyframe Value with Expressions
    Posted by George Henderson on November 2, 2023 at 5:03 pm
    Hi there
    I haven’t had much luck setting up the following action; could someone please explain how to achieve the following? <b style=”font-family: inherit; font-size: inherit; color: var(–bb-body-text-color);”>(A sample project is attached.)
    1. I have an object in my comp called ‘Square’ and a null layer called ‘Controller’ with a ‘Checkbox Control’ effect on it.
    2. The scale attribute on ‘Square’ has a keyframe on frame 20 with a value of ’50’ and a keyframe on frame 50 with a value of ‘100’. (A simple scale-up animation over a second (30fps)).
    3. When the checkbox is checked, I want the value of the second keyframe to be subtracted by 25. So, instead of going from 50 to 100, it’ll go 50 to 75.
    Any help would be greatly appreciated.
    Thank you!
    Brie Clayton replied 2 years, 10 months ago 3 Members · 3 Replies
  • Dan Ebberts
    November 2, 2023 at 5:12 pm
    Since your keyframes are linear, you could do something like this:
    sc=thisComp.layer("Controller").effect("Size")("Checkbox").value;
    sc ? linear(time,key(1).time,key(2).time,key(1).value,key(2).value - [25,25]) : value
  • George Henderson
    November 8, 2023 at 11:08 pm
    That did it; thank you so much, as always.
  • Brie Clayton
    November 8, 2023 at 11:09 pm
    Thank you for solving this, Dan!
