Activity Forums Adobe After Effects Expressions Control Z Position of multiple Layers with one controller
  • Control Z Position of multiple Layers with one controller
    Posted by Marcel Schobel on June 9, 2020 at 7:58 am
    Hey Guys and Gals…
    i try to do the following:
    i have a grid of letters (all 3D layers) ..evenly distributed all over the screen… z Position is 0 …
    now i would love to have an expression that allows me to change the z Position for all layers randomly … so when i change one value (in a slider maybe) the letters move in Z …without jumping every frame …
    i have come to a dead end with my limited expression knowledge …
    i would appreciate any help
    m.
    Marcel Schobel replied 6 years, 2 months ago 2 Members · 2 Replies
  • Robert Müller
    June 9, 2020 at 10:36 am
    Hey Marcel, this should do what you are looking for:
    fac=thisComp.layer("ctrl").effect("factor")(1) //slider on a Null layer
    x=value[0];
    y=value[1];
    rdmMin=-100; //Min random value
    rdmMax=100; //Max random value
    rdmSeed=123456 //random seed
    seedRandom(rdmSeed, timeless = true); //timeless is true, so the value doesnt update every frame
    rdmVal=random(rdmMin, rdmMax);
    z=rdmVal*fac;
    [x,y,z]
    Now when you animate your slider on the control layer from 0 to 1 the layers will start moving up to their random z position. You can increase this if you go beyond 1.
    If this is not random enough you could always factor each layers index into the seed, so you would have a individual seed for every layer. If you want a more natural random distribution you could use “gaussRandom()” instead of “random()”
  • Marcel Schobel
    June 9, 2020 at 11:16 am
    Thank you Sir !
    this does the trick. I am pretty solid at After Effects in all areas EXCEPT for Expressions. I wish i could wrap my head around that. I can even understand/interpret your expression (kind of) BUT i just cannot come up with one myself … i will try to learn in the next couple of weeks …been neglecting expressions for way too long.
    thanks again for your time and kindness
    regards
