Activity Forums Adobe After Effects Expressions Control x position with text width when source text is linked to another layer.
  • Control x position with text width when source text is linked to another layer.
    Posted by Luis Abaladas on June 9, 2020 at 9:55 am
    Hi guys!
    I have a Main Text Layer, controlling the text from another Text Layer (with different text styles from the main text layer).
    I do have a 3rd Layer that needs to be affected by the position of the Text Layer width.
    In my head that would be something very straight forward to do. I should just use something like
    thisComp.layer("Text Layer").transform.xPosition + thisComp.layer("Text Layer").sourceRectAtTime().width;
    Unfortunately, the expression is reading the width of the Main Text Layer instead of the Text Layer .
    I’m also having the text-align to the Right, so the 3rd Layer should be moving to the left direction but I guess that’s just using a – instead a +.
    Thanks in advance!
    Luis Abaladas replied 6 years, 2 months ago 2 Members · 2 Replies
  • Robert Müller
    June 9, 2020 at 10:57 am
    Hm, this sounds about right to me. Can you post a screenshot of your setup, like how you have linked the different layers?
  • Luis Abaladas
    June 9, 2020 at 1:19 pm
    Yup, it was right… just me being a potato.
    I just realized that the text layer had a scale.
    Just multiplied the scale value to the .sourceRectAtTime().width and it works just fine.
