Activity Forums Maxon Cinema 4D Control where particles fall
  • Control where particles fall
    Posted by Addie Kennamer on February 11, 2020 at 6:17 pm
    Hi! I am fairly new to C4D and am trying to create an animation describing Leaky Gut. I need particles to only fall in the cracks of my epithelial cells I have created however, when i add an emitter above them they obviously just fall all over depending on the size of the emitter. The cells start together and then separate and when they separate is when i need the particles to fall through the cracks of separation only. Is there a way to control the particles to where they only fall between the cracks of the cells? I have posted a picture below to hopefully help understand a little better. Any help would be appreciated!
    Jim Scott replied 6 years, 6 months ago 2 Members · 6 Replies
  • Jim Scott
    February 12, 2020 at 1:45 am
    One way would be to use some other collider objects (set to not render) in order to funnel the particles into the cell openings, as well as multiple emitters for better control. And a wider funnel shape at the top would make it look like the particles were being sucked through the openings (assuming that’s what you want).
  • Jim Scott
    February 12, 2020 at 4:05 am
    Or, perhaps more elegantly, one emitter and multiple funnels.
  • Addie Kennamer
    February 12, 2020 at 2:10 pm
    Thank you! How would I control how the emitter particles falling into the funnel only? Right now they’re just going through through the objects if they touch them.
  • Jim Scott
    February 12, 2020 at 4:44 pm
    Along with a rigid body tag on the particles, you need to add collider body tags (“Dynamic” – off, Shape – “Static Mesh”) to the funnels. Here’s an example below. For the funnels, the lower “traffic light” is set to red (Visible in Render – Off) so they won’t render. I also set the particle “Speed” to zero and set gravity to 300 cm (Project > Dynamics > General) so that the particles would fall more slowly. (I just added transparent materials to the funnels so that they would be more see-through in the Viewport and for the screenshot than enabling “X-Ray” in their basic properties.)
    14024_leakygut2.c4d.zip
    Edit: you also need collider body tags on the epithelial cells so the particles don’t go through them.
  • Addie Kennamer
    February 14, 2020 at 3:56 pm
    Got it! Thanks so much!
  • Jim Scott
    February 14, 2020 at 4:23 pm
    You’re welcome. Glad it helped.
