Activity › Forums › Adobe After Effects Expressions › Control values from two locations
Posted by Paul Ducco on November 3, 2022 at 7:01 amIs it possible to control values (i.e, position) from two locations?
As an example, I have a shape layer with a position controlled by a Point Controller, BUT it would be very useful for someone to manually grab the shape layer directly and drag it in the comp window.
Dreaming? 🙂
Paul Ducco replied 3 years, 10 months ago 3 Members · 7 Replies -
Andrei Popa
November 3, 2022 at 7:38 amHow would the position property know where to take its values from?
Paul Ducco
November 3, 2022 at 8:01 amThat’s the conundrum though isn’t it…they’d both be right…because they’d both be the same value. Just how they are set might vary. i.e, a user might set some keys with the Point Controller, but then decide to adjust those keys in the Comp window (directly and visually).
Make sense?
(In the same way we could position a layer in a comp with value controls, and/or just grab the layer and move it.)
I know this might be a bit of a brain-breaker…but I SWEAR there’s a potential use case for this.
Filip Vandueren
November 3, 2022 at 8:19 amJust add +value to the end of an expression and fix the value to 0,0
So you can tweak it keyframe an extra offset in 2 places. They just get added together.
Paul Ducco
November 3, 2022 at 8:25 amHAHAHA. Gold. Thanks Filip.
Here I was using all sorts of wild if() statements.Thanks mate.
Paul Ducco
November 3, 2022 at 8:30 amActually. testing that now…it works…however keyframes aren’t getting set. i.e, if the Point Controller is used it will key it there, but not on the shape layer and vice versa. Or have I misinterpreted your explanation?
Filip Vandueren
November 3, 2022 at 10:33 amI thought that was the whole point, being able to keyframe both parameters?
You can’t move the layer and have after effects interpret that as having to add a keyframe to a point control.
If the effect is selected, and show extras is enabled, the point control is visible though and can be set /keyframed from within the comp-viewer too
Paul Ducco
November 3, 2022 at 10:07 pmYep cool. See…dreaming. 🙂
Thanks again Filip, I guess I was overthinking it
