Activity Forums Adobe After Effects Control time with beats?
  • Control time with beats?
    Posted by Ocean Byrne on September 4, 2014 at 9:24 am
    What is the easiest way to play with slowing down and/or strobing the the play back speed of my video – to a beat?
    More or less I’d like to:
    First play my audio track, and hit “0” on the numeric to mark my beats (which change over time, not just one simple rhythm)
    Then I’d like to essentially Time Remap my video, so it the first beat holds on frame 1, beat 2 frame 2, etc…
    Then I’d like to be able to adjust a variety of sliders that change things like-
    Source Jump Rate 5 — beat 2 frame 5, beat 3 frame 10…
    Sub Beats 4 — each beat gets broken into 4 beats, which then jump by the Source Jump Rate
    Play Rate — independent of how far each jump is,I’d like to then be able to control if it just sits, or plays at a variable rate
    Then I’d like to add fades and flashes and “what not” on some of the strobes as well…
    Any tips or suggestions on the best way to set something like this up? Better yet a scene file with it already all set up, and a chocolate bar.
    I’m also curious the best hot-key workflow to quickly jump in time and create new numeric valued key frames in your selected channel, all on the keyboard?
    I know the page up/downs and shifts
    What about jump to next/prev marker? (on a different layer?)
    Create new keyframe here and let me type in its value?
    and so on…
    Thanks for any help, could be fun in the end!
    Michael Szalapski replied 12 years ago 2 Members · 1 Reply
  • Michael Szalapski
    September 4, 2014 at 2:12 pm
    Check out this tutorial: https://library.creativecow.net/articles/stern_eran/MarkersLeaks.php
    In it, markers are used to drive expressions to get flashes. You would need to adapt that to your project, of course, but it should start you off in the right direction.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
