Activity Forums Adobe After Effects Expressions Control time of composition with slider control (in seconds)
  • Control time of composition with slider control (in seconds)
    Posted by Saso Goricar on October 16, 2018 at 6:58 pm
    Hello,
    I have one question about the problem. I’m creating a .mogrt file and I want to add a slider control to control the duration of the animation (composition). Is there an expression to fix that, that I can change the duration of composition (duration in seconds) with just a slider control.
    Thanks for the help.
    Saso
    Duane Walters replied 5 years, 7 months ago 3 Members · 6 Replies
  • Dan Ebberts
    October 16, 2018 at 7:26 pm
    You can’t control duration with an expression, but you could drop your comp into another comp, turn on time remapping, and use a time remapping expression like this:
    s = thisComp.layer(“Controls”).effect(“Slider Control”)(“Slider”);
    linear(time,0,s,0,key(2).time)
    Dan
  • Saso Goricar
    October 16, 2018 at 8:04 pm
    Thanks, that is exactly what I was looking for. Thank you very much, you are a lifesaver.
    Do you know if this expression works in new version AE cc 2019 with the new feature “Create protected region”?
    Thanks again.
    Saso
  • Dan Ebberts
    October 16, 2018 at 8:35 pm
    I haven’t played with that feature yet. Try it. ☺
    Dan
  • Saso Goricar
    October 17, 2018 at 7:57 am
    I will, thanks for your help.
    Saso
  • Duane Walters
    February 10, 2021 at 8:59 pm
    In 2021… it does work, but it doesn’t actually honor the protected regions, is there a way to do that?
  • Duane Walters
    February 11, 2021 at 4:52 pm
    Never mind, I have re-evaluated my needs to just use protected regions 🙂
