Activity Forums Apple Final Cut Pro Legacy control surface for multiclip?
  • control surface for multiclip?
    Posted by Jeff Stroming on August 16, 2008 at 8:06 pm
    I am looking for a control surface for FCP (specifically multiclip) that will function like a video switcher. Too many buttons on the keyboard that accidentally get hit when editing shows with more than 4 cameras. Any input would be appreciated.
    -JEFF
    Ben Scott replied 18 years, 1 month ago 5 Members · 4 Replies
  • Zane Barker
    August 17, 2008 at 12:10 am
    When editing using multi clip you actually just click on the clip you want as they all play, you don’t actually use the keyboard in choosing them. But as far as a external switcher to use with FCP I do not believe there is one.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Arnie Schlissel
    August 17, 2008 at 1:35 am
    [Zane Barker] “When editing using multi clip you actually just click on the clip you want as they all play, you don’t actually use the keyboard in choosing them.”
    You can set up the keyboard for multi-cam editing. I think the default uses the number keypad & one of the command or option keys. you can re-map these keys if you want.
    [Jeff Stroming] “I am looking for a control surface for FCP (specifically multiclip) that will function like a video switcher. Too many buttons on the keyboard that accidentally get hit when editing shows with more than 4 cameras.”
    I don’t think there’s any switching surface available. And I don’t see what difference it would make. The part that makes me hit 2 when I mean to hit 4 is the part that’s inside my head, not the part that’s on the keyboard.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Andy Mees
    August 17, 2008 at 3:33 am
    the control surface is the keyboard and you can map keys as you like
    given that, there’s absolutely no reason why you couldn’t use any old programmable keypad as a dedicated control surface for your switching needs
    how about this one https://www.xkeys.com/xkeys/xkbuttonp.php
  • Ben Scott
    August 19, 2008 at 8:35 am
    have been looking into this control surface which looks well nice
    it is programmable and works with final cut pro
    https://www.frontierdesign.com/Products/AlphaTrack
    there is another compatible one for even cheaper
    https://emusician.com/controlsurfaces/frontier_design_alphatrack/
    Check my podcast at https://cowcast.creativecow.net/final_cut_pro/index.html
    or my site at
    https://www.benscottarts.co.uk/ – – – – – – – – –
