Activity Forums Adobe After Effects Expressions Control speed of comp (time remapping) base on speed of position property
  • Control speed of comp (time remapping) base on speed of position property
    Posted by Frederic Antoinette on April 22, 2018 at 3:48 pm
    Hi, as the subject says.
    I have a fish tail animation inside a comp, and I’d like it to speed up and slow down to normal speed, based on the the velocity at which the fish is moving.
    I did found this post that pretty much does it but with the exception that if the body stop moving it also freezes:
    https://forums.creativecow.net/docs/forums/post.php?forumid=227&postid=7523&univpostid=7523&pview=t
    I readapted the code to this, but I’d like to keep going at normal speed if there speed is 0
    p = transform.position
    dampen = 5000;
    dur = this.source.duration;
    finalTime = 0;
    for( i = 0; i < time; i+= thisComp.frameDuration ){
    xVeloc = p.speedAtTime( i )+1;
    finalTime += xVeloc/dampen;
    if( finalTime < 0 )
    (dur + finalTime) % dur
    else
    finalTime % dur
    Frederic Antoinette replied 8 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    April 22, 2018 at 5:09 pm
    Try changing this line:
    to:
    xVeloc = p.speedAtTime( i ) + dampen*thisComp.frameDuration’
    Dan
  • Frederic Antoinette
    April 22, 2018 at 7:27 pm
    That did it.
    Thanks Dan
