Activity Forums Adobe After Effects Expressions Control speed influence between two keyframes with marker
  • Control speed influence between two keyframes with marker
    Posted by Thiago Costa on November 1, 2017 at 2:31 am
    Hello everybody, just thought of something that I think could be usefull for a lot of people.
    Everytime I try to make more complex camera movements, I end up parenting the camera to more than one null in sequence. This way, I can control, for example, specific camera movements from one null, while the camera follows another rotation from the second null in a different anchor point. Then, to get a movement that is more “organic”, I need to offset some of the keyframes, but keep the highest value of speed the graph of all keyframes on the same position on the timeline.
    I put together two pictures showing the problem and the solution that I imagine could make this job easier, faster and less tedious.
    So, you select two keyframes of a specific parameter on lets say, 4 or 5 layers, run the script, then control the highest value on speed graph with the marker.
    Is it a possible thing to do? Would I have to split the layer afterwards because of the expressions? Or would I be able to do this as many times I want on the same layer?
    Thank you in advance!!
    Thiago Costa replied 8 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
