Activity Forums Adobe After Effects Expressions control specific scale property values with a slider control.
  • control specific scale property values with a slider control.
    Posted by Luis Florez on August 28, 2016 at 10:50 pm
    hi
    I want one slider to control the scale property like this; if the slider control is any value from 0 to 50, I want a layer to be 50, anything else same as the slider.
    I am using this expression to accomplish it, but it is not working.
    s = comp(“comp”).layer(“layer”).effect(“effect”)(1);
    linear(s,0,100,50,100)
    i have tried this one too to identify the two properties.
    s = comp(“MAIN DESIGN”).layer(“MAin Control”).effect(“Logo Texture Size”)(1);
    linear(s,0,100,50,100);[value[0], value[1]]
    this one doesnt show errors but doesnt work.
    it seems to me I am writing it wrong because the scale property has two values.
    how can I fix it to accomplish what I want?
    I used it in the opacity property and it works fine but not in the scale property.
    I dont know how to write expression, I am learning.
    Any help will be much appreciated.
    Luis
    s = comp("comp").layer("layer").effect("effect")(1);
    Live your life with passion
    Luis Florez replied 10 years ago 2 Members · 2 Replies
  • Dan Ebberts
    August 29, 2016 at 12:20 am
    I think it will looks something (not exactly though) like this:
    slider = comp(“comp”).layer(“layer”).effect(“Slider Control”)(“Slider”);
    s = Math.max(slider,50);
    [s,s]
    Dan
  • Luis Florez
    August 29, 2016 at 5:25 am
    yes. Dan. thank you so much. it works perfectly.
    I dont know how you do that.
    Amazing.
    one more question though.
