Activity Forums Adobe After Effects Control Scale with Null Position
  • Control Scale with Null Position
    Posted by Brian Altman on February 24, 2010 at 4:47 pm
    Is there a way to control a layer’s scale by using the position of a null and/or gradient?
    For example, let’s say that you have a grid of boxes. Each box is on it’s own layer. Is it possible to then drag a null from left to right that will scale those boxes up as it moves past them?
    Thanks for any help!
    Michael Szalapski replied 16 years, 7 months ago 3 Members · 5 Replies
  • Andy George
    February 24, 2010 at 5:13 pm
    Hi Brian,
    Is there a reason you want to use a null or gradiant?
    The way I would scale multiple items is like this-
    Create a null object and apply the “slider” effect from the
    expression controlls effect catagory.
    Open the scale property of the first item I want to control the scale of (“layer_1” lets call it)
    and option click on the stopwatch to reveal the expression controls. Quickwhip
    the scale property to the slider effect on the null object.
    Now select layer_1 and go to edit>copy expression only.
    Select the rest of the layers you want linked to the null and paste-
    -Andy
  • Brian Altman
    February 24, 2010 at 5:28 pm
    That works for scaling all of the objects at the same time. I’m trying to figure out a way to “grow” the objects on in a linear way.
    It would be similar to manually setting the scale for all objects from 0 to 100%, and then offsetting the layers so that they scale up starting on the left and ending on the right. Does that make sense?
    The problem is that I am going to be working with a ton of layers and would rather find a more efficient way of working.
  • Andy George
    February 24, 2010 at 5:44 pm
    Hi Brian,
    Yes that makes sense. You could use a “follow the leader” expression,
    which would allow you to set a consistent offset between each scale.
    Is that what your looking for? Here is a article that does a good job
    of breaking down Time offset in expressions.
    https://www.creativemac.com/2003/12_dec/tutorials/followtheleader.htm
    -Andy
  • Brian Altman
    February 24, 2010 at 6:01 pm
    I think that just may work; although I already have it set up in my 3D app for this particular project!!
    Thanks for the tip…I’ll review that link for future use.
  • Michael Szalapski
    February 24, 2010 at 6:33 pm
    Check this out. It uses expressions on a null object (mouse layer) to drive the scale of objects.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
